Mcx 270 at low elevation
Duramax325
Just wondering if anybody is running a 270 at low elevation and if so what does your setup consist of clutching and boost if possible
I run 15 lbs of boost at around 1600' - 2400 on premium 162" camo extreme
Mcx 270 kit with head shim .
Epi black spring in secondary wound 0-1 47 degree helix
Dalton's loaded to 65 g in primary 14.5mm rollers
I also run the same set up to 9000"
Dalton's loaded to 65 g in primary 14.5 pins
Sorry but what does this mean
"EPI black spring in secondary wound 0-1"
