I have a complete Aero 53 series OVS turbo kit from my 09 M8 for sale, I bought it from a buddy who ran it on an 08 M8 as well. Apparently we were both of the same opinion that we needed more boost but this kit flat out works!!!
I have a (brand new this yr) high flow fuel pump and capacitor set-up (from Shain@ Twisted Turbo) to run the additional electronics without cutting into your stock harness, sent the turbo to the turbo doc this last fall and had him go through it and it was in great shape, changed the oil and set it up for 8lbs and thats what it runs.
It will come with additional throttle bodies, (you'll need your injectors) Pure Logic fuel controller, fuel psi regulator, Aero 53 turbo and stand with a cold air intake, Twisted turbo's Y-pipe additional spring holding clamps, all clutching for the older secondary, (non-engine reverse) and a primary spring with Cutler adjustables (not shown in pic) airbox, charge tube and also the boost and AFR gauges, along with the capacitor and fuel pump.
I also have the stock y-pipe and pipe if you would happen to need it
I'm gonna put it out there at $2650 plus shipping, but I'm definitely open to realistic offers. There is nothing wrong with the kit, I simply upgraded. Located in MN
PM me if you have any more questions or need additional pictures, I have pictures of how everything was mounted befor I removed it. I know the kit quite well...
