M1100T cans
dejadoo
Looking for reports on M1100T cans, did a search and not much posted lately.
I went with a Speedwerx(wanted a quiet one)and couldn't get ceramic, so ended up with black and my side panel and top of my belly pan are pretty much a puddle now. I am going to try something else, a little louder would be OK, no heat problems and weight reduction the most important.
What works best?
I also have the speedwerx can on mine and my plastic melted real bad too. I have a vent kit and heat taped the inside of the pannle and put hedder wrap around the can and it stopped the melting issue. I also know that the d&d can will melt the pannle also. Ive heard that the people running straight pipes are not having melting problems. Hope this helps.
I have a D&D barker. It's not really that much louder and I have no problems with melting.
Had no heat issues with a couple dozen Hindle's we build, any straight pile, and some mbrp mufflers we did.
Turbo dynamics can on mine since day 1, great sound no heat issues and stainless steel, I believe they used vibrant for the muffler. now just need the larger turbo pipe and I'll be at 200hp or darn close.
I have the D&D. No melted panels but the top cracked out on it. New one should be here today or tomorrow on warranty. Not to loud and it sounds good!
M1100T muffler
I don't have any problems with my DD big barker muffler, it sounds good, is ceramic coated and and hasn't melted anything yet.
I am running quiet BMP and boost tubes, great performance and no melting. Much quieter then the darker. It doesnt even get hot enough in the middle of the can to warm up my hot pocket in the hotdogger?? I also have the 9 piece moutain fit vents.
Another vote for the D&D Barker.
Mine is a ceramic coated stage II which is middle ground for sound.
No heat or melting, plus really light and builds HP!
Ive been running a stainless 2.5" straight pipe and have had no heats issues in 500 miles.
In looking at the stock can, I see there is insulation under the first coat of stainless....
HEAT!
I think any aftermarket can will make more heat under the hood than stock, UNLESS it is ceramic coated or header taped.
I will be looking for a can that is ceramic coated.........
That weeds out Speedwerx and who else?
Correct me if im wrong, but that stock can on my turbo is not stainless by an means, which is why they have to wrap with insulation and cover it a thin layer of sheet metal. Stainless will not absorb the heat as much. I have had NO heat issues with the all stainless exhaust.
HEAT!
heat
Obviously vented side panels are a huge benefit. My straight pipe is 4" from my battery and it has no issues, but I have side panel vents and the ones on the left and right sides on the hood.
venting
The side panels are factory Cat ones, as are the LH/RH hood ones and the vertical one behind the bumper. I cut the LH/RH into the hood when I built it. The headlight intake plenum and over the intercooler are Frogskins as well.
