Low boost Actuator
W
WITHERS
Does anyone have an idea on the max lbs of boost you can run with the low boost actuator? It's on a cpc stage 2 kit. Should the tab that comes off the wastegate be in a vertical position(this is where the rod from the actuator connects). I never noticed it before but it seems that it would not be closed all the way like this. Any ideas/help would be great.
if you just have a hose (no boost tee) running from the charge tube to the actuator, you will only boost what the actuator is set at. If you put a boost tee in line you can raise up to as much boost your turbo will make or adjust anywhere from there down.
