I'm lazy, do you have the part numbers for the parts needed?
the 208 tore the old 120 track up. It's long track time.
what windshield did you use on this build?Can’t wait to start mine!
Thing looks sick. We are working on. My youngest son's at the moment. Do you happen have a good picture of the underside of the track. We are struggling with the parts we got and how to assemble the skid.Ended up well. Stage one mods anyways. I did the longtrack and tackling the engine now.
Night and day difference in where the 120 can go and how much more traction it has.
-Rec Motors Aggressor Kit
-Rec Motors Race Shock Kit
-Upgraded clutch and gearing
-ZR200 track, rails, driveshaft/drivers, tunnel extension. Powdercoated with billet wheels
-C&A Pro Skis
-Proclimb windshield
-Modified steering 3” forward
-South Simcoe Machine Billet pull handle
208 goes in this summer. And upgrading front shocks. I also have a Fox Float for the rear but I might keep this race shock kit as long as the shock holds up. So far so good.
Also thinking about getting a tooth larger driver made. I’ll have to relocate the driveshaft location but since we are only dealing with lengthening the chain and building a guard it shouldn’t be that big of an issue. With the relocation of the rear skid( I dropped it a few inches and moved it back the same) it ratchets regardless of how tight I make the track. So larger drivers might let me have more teeth contacting the track at the same time. I also just thought of installing simple guide drivers on each end to keep the track from flexing which might help as well.
-C&A Pro Skis
Hey I'm In the middle of this swap right now. I'm running a 212, And wondering what gearing I should run.Hey Mike, I was gonna add to our conversation, I'm not familiar with the longtrack kit however I used the normal kit and remounted it to give me the lift i needed while still working as it should with my sons weight.
