i dont know what it is i just dont want to get rid of this thing
next season ill be swapping in a 600sdi and running 8lbs boost through it
2001 summit 600 chassis 144x2
- powdercoated suspension rails
- powdercoated belt guard
- powder coated trailing arms
- Boondocker liquid nitrous system
- 3.0lb bottle and adjustable regulator 10-50hp shots
- 2000 series injection manifold
- Nitrous express pressure guage with anodized t fitting and 2ft braided extension
- over bore kit with wiseco performance pistons 630cc
- Boss lightweight seat
- polishing tunnel
- mountain machines 2 wheel conversion kit
- tricked toys billet wheels
- tinted headlight splitter
- ceramic coated dynoport single pipe and can
- exhaust manifold with weld on egt fittings
- dual screen dt52sn digatron. rpm/egt/egt
- pro taper hanglebars
- billet pull cord
- brtech venting kits
- custom made hood bra
- polycarbonate lightweight flexable hood
- headlight and electronics deleted
- boondocker voltage resistor
- mountain addiction rear gas rack with 2 slide off cans
- hpe throttle block
- powermadd pivot adapter and 4" block..total 5.25" rise
- powermadd throttle cable extension
- powermadd chrome brake line extension
- low profile windsheild
- sidehiller 2 skis from newer chassis
- DJ clutch kit, billet helix, primary spring, secondary spring
- dalton pro adjustable pin weights
- skidoo hpv-27 rer secondary clutch conversion
- hpg center shock from 440 race sled
- interior rail wheels deleted
