Lethargic boost?
Tony try loctite 770 if you can't get 404, it also works very good at bonding rubber.
I had a leak like that, my sled was opposite of lethargic !! it was running like a raped ape as it was leaning out !!! it caused a lean condition and damaged my pistons. I ended up with a fresh top end under warranty ... so if you are noticing a high idle and if your sled is running too good, then its probably too good to be true ;)
?‍♂️ I just ordered one from Babbits and it will be here next week.
Just wrapped up a ride and was having this exact issue, seemed to idling and running fine but topping out at 7,900-8000 and then falling off hard. about to tear mine down and check for rips.
I see part 5417730 on Babbitts but did you actually confirm availability with them?
tony do you think that broke under normal conditions or do you think it was stressed from installing a can or some other reason?
I think the ‘22 mounting doesn’t have enough flex built in. The throttle body and boost box are fairly solid. It will be interesting if the ‘23 does it as well.
1642 miles on mine. I’m hearing of a number of ‘22s with the same issue.
