First of all let me say, I think all the aftermarket skids in the market place are better than stock. It is the aftermarket that drives the industry.
Allan, I could go on and on about the Mountain Tamer and how I would do it different, but I won’t.
I will address our difference of opinions on some things about design.
Through our exclusive testing we came up with equal length arms for a coupling skid. We have found that with equal length arms the skid works more in unison rear to front when coupled.
To have three different front arm lengths means three different geometries; all designed to fit different vehicles, just to mount in the stock position in the tunnel. With all of our testing it is not as consistent in the way the skid works vehicle to vehicle in our opinion.
We mount in the tunnel for the skid, not build the skid different for the vehicle. That way each vehicle can be tuned similar and predictable. We can mount the same skid into an M Cat, Ski Doo XP, XM, and Polaris Pro with just minor tunnel mounting adjustments. (On Yamahas we mount higher in the vehicle to lower ride height but takes a different rail).
Ride height is addressed with spring preload,(as mentioned before) along with tunnel mounting higher in the rear to lower the ride height close to stock; we are a little higher in the rear if you pull up the entire ride in, but have longer travel than most (near 19’’ of rear axle travel).
Our springs are designed by Raptor Shocks, (they are not off the shelf springs) they are designed on a CAD spring program and then field tested to come up with our rates and design. Spring rates are not rocket science (1’’ stroke = pounds of rate) but packaging it to a custom length and stroke along with a higher rate at some point in the stroke, that’s when the pros earn their money.
The preload in our dual rate springs are just that; we increase the load not the rate (don’t confuse the difference between load and rate). We can run little pre load with our spring for lighter riders and then increase the pre load for a heavier rider to help hold them up, but the rate never changes so the characteristics of the skid acts the same. With our full 4.95’’ of shock stroke we can preload the spring up to 1.5’’ of pre load and still not coil bind the spring at jounce. (This is how we can get to the broad range of adjustability for different weight of riders).
Dual rate spring rates, are so many pounds per inch with a shift point, and then it transitions into a higher rate per inch for the remainder of the stroke. Now with a heavier rider we may need to increase the dampening a little firmer for a bigger load, no problem just a few clicks on the Raptor piggyback and you’re ready to go. That is how we get to a skid that will perform equally for a 120lb to 250lb rider all in the same spring and shock package.
Fully tested and customer indorsed.
We also have a big guy spring that will handle guys from 250-350 lbs.
We each have our own way, which is what aftermarket is all about.
Thanks, Kevin
