Read through lots of posts on what to do, but its all from 2011. I'm looking for some updated info and what has worked for a couple years! Right now the sled is completely stock (never even changed plugs and only on the second belt) w/ 1500 miles. Right away I'm not looking to dump all the much into the sled hopefully keep around $600 or so. Thinking a Can (for ditching weight and sweet sound) and some clutching work should wake it up even more.
Has anyone ever found a can that has worked at 1500ft that doesn't turn into a dog in the mountains at 9k feet? I'm trying to stay from a super loud one if that's possible, but performance will trump noise level.
What about the clutch set up? Has anyone tried the MDS weights, or do others work just as well? I can't really wrap my head around spending that much on weights and how just changing weights will really wake up the sled that much. Any other clutch updates/set ups that I should check out? I've heard good and bad things about torsional set ups effecting reverse. Do they have that figured out now?
I've read a bunch on the DD bearing update and have an skf bearing ordered, hope no machining has to be done...
I'm in ND and out here ride between 1500 and 2500 feet, with trips planned to Cooke City which gets up to around 10,000. I'm 215 w/o all the gear on (if that matters).
Thanks
Thanks
