Guys, I got the Barcode kit mounted up on 2015 Proclimb 153" yesterday. I will measure the front end height change and post it later. I am wondering if I should change my ski pressures (currently at 60 PSI clutch side and 58 PSI muffler side). Also, I seem to remember reading that there is more ski pressure with the lengthened front end. Should I also increase my front track shock pressure before (1.2 or 3 threads) before heading out tomorrow)?
I'm anxiously awaiting your thoughts on the barcode kit, I really hope you like it! I really like my set up. It took me a day to get used to it. I forget to mention that I let my limiter strap out 1 hole as well. If ya wanna bullshit about it, give me a call, easier to talk than type.... 586 675 6213Guys, I got the Barcode kit mounted up on 2015 Proclimb 153" yesterday. I will measure the front end height change and post it later. I am wondering if I should change my ski pressures (currently at 60 PSI clutch side and 58 PSI muffler side). Also, I seem to remember reading that there is more ski pressure with the lengthened front end. Should I also increase my front track shock pressure before (1.2 or 3 threads) before heading out tomorrow)?
What skis do you have? I had the skinz kit (not exactly apples to apples) on my 14. Need an easier turning ski like grippers. Started out with powder pros, those only lasted one ride.Thanks, I may call you after I ride it, thanks. My limiter strap is all the way out, there's no room for any further adjustment unless I get a longer strap. I am currently in the middle hole on the rear drop down brackets and the lower rear hole on front (tunnel) holes.
Say what?
What type of shock is dependent on orientation? They're all pressurized in the damper with either a bladder or a piston for oil displacement.
Hey! Yup it defiantly takes a bit to get used to riding the kit. FYI. its also fantastic on the Alpha!
Cheers
Allan
now make a kit for the 40-42" (xf high country's) wide sleds, PLEASE. Ski
Kinda defeats the purpose doesn't it?now make a kit for the 40-42" (xf high country's) wide sleds, PLEASE. Ski
With some adjusting of the heims on the arms and depending on what skis you have you can get the kit to about 38" .
I believe he means that the barcode front end is to help make the sled 'tippy' get that 36in front end so u can sidehill easier.Why? xf 141 with a 2.25" cant go in the deep? Ski
