Pictures of jack shaft
These pictures should help to remove doubt to what is going on with the belt drive. This out out af a 2013 pro rmk use as a rental sled. It had 2500 miles when this shaft was replaced on the right, new shaft for comparison on the left. I ran the new shaft in it another 1000+ miles. The new shaft now looks like the old shaft. No doubt the shaft is turning inside the bearing, which is also causing extremely high top sprocket temps. Maybe regluing the bracket or bolting it is the answer. I have got to believe Polaris will be coming out with a fix soon. I bet there are many more sleds out there with this problem than are not recognized at this time. The problem surfaces with mileage and the sled will still run with the bearing in the shape as pictured, it just starts to clunk on hard excellerations.
