Is the 488 called the 500?
COP-OUT
365
60
LEWISTOWN,MONTANA
1990 Classic
We had a 1990 500 Polaris Classic with a 488c liquid cooled engine. Never a probably with the engine. Always ran great. We did have a wiring issue. That's because Polaris decided to run the wiring harness under the engine. Cleaned the connections and used some dielectric grease and that solved the problem.
the fix-it guy
138
cottonwood,mn
The liquid cooled 488's were referred to has 500's. Sleds with the fan cooled 488 usually had "trail" in their name. Polaris also made a domestic 500, little brother to the big twins.
SpencerA
679
18
18
Portland Oregon
So this is the 488 fanner. I'm not mistaken aren't these one of the most reliable motors polaris made? I know being a fan cooled motor you don't get the performance but this will be used to put around the groomed trails with the little ones.
F
Dec 10, 2007
963
54
Yellowknife, NWT
Haha whatever you do dont try make MORE power with these motors, they just fall apart.
But the older fugi 488/500 liquid/fan both shared the same bore and the motors nearly looked the same, I believe the Stator/clutches/crank/pistons/CDI and a few other odds and ends were the same. Both slow but reliable. The domestic 500 was a way different animal all together.
V
volcano buster
1,641
Stayton Oregon
Well, in that case, I have a 340cc twin sitting on the shop floor. With over 8700 break-in miles it should be just broke in for your application.
polrmk
39
6
8
Goodhue, MN
I had a 1987 Indy Trail, 488 fan, it had something like 9000 miles on it when I sold it. Did put new pistons and crank bearings in it once. I did bore the engine enough to make it a true 500 cc, maybe like 40 thousandths. Not much to tear those motors down. It would get to about 60 mph pretty quick. That sled made trips to northern Minnesota and the Black Hills and a lot of SW Minnesota miles.
MTsled3
746
719
93
Belgrade, Montana
My dad still has a 1990 500 sks with the liquid 488, rebuilt it once in 96, and the crank bearings just went out at the end of last season, and now he's rebuilding it again. It has approximately 13,000 miles on it, (rough estimate, odometer broke about 5 years ago and reads 11,000) sled has been super reliable, and myself, my little sister, and my little brother all started out on it. I'm 19 now, and I was the one riding it last year when it finally crapped out on us. It's a blast to ride even with not much power, and back in the day my dad took it places I have yet to get to on my 03 rmk
