This motor is the new 600 long rod motor with the cfi 800 topend on it, it uses the 40mm race carbs and timing. At sea level I started at about 470s at 35 degrees, I was down to 440s, it wasnt bad except for about mid throttle, it would clean out at wide open, but my egt's would not hardly get over 1000. I am running a sinlge pipe from neils power pipes. I was told to keep my egts below 1200 on a single. I have tried some different secondary setups at sea level that didn't work to bad. If you want corner to corner trail setup the race setup is pretty close, I just need to drop my primary weights to 10-64 from 66. I have also tried a 64-40 .46 helix with the purple team spring, dont remember exactly what rate it was, but it is what I was told to run at 9000 feet. These are just some of the things I tried late in the year once I got my motor in. Carls cycle thinks that this motor should pull a 10-68, It will not pull that in an IQR with a 136" track. I am just trying to get some feedback from others that have had this motor for more options so when I do get back out west I am ready to ride and not tune the whole time.
