Pics and Details
Product Description
New for the 2014/15 snow season is the IceAge Pro-Motion.
This is a bolt on drop in rear scissor arm replacement that allows the rear suspension (aka "skid") to pivot.
Not for use with aftermarket suspensios. Only works on OEM skids.
AVAILABILITY:
***Units are in production, and will be available for the mountain snowmobile shows starting early October. To preorder a kit, email nick@iceagemfg.com with the following info, Name, Number, make of sled, color desired. Pre ordered kits will be shipped before any others***
NOTE: We will not charge your credit card until your unit ships.
*Function*
3* of flex in both directions(50% more then T-Motion)
Get sled on edge easier
Reduced effort to sidehill
Cut through cross rutted hills smoother
True bolt on, no cutting, modifying etc
Comes complete with all hardware for easy install
15-30 minute install time with no need for skid removal
*Application*
Natural aluminum ($295) and black, red, blue and green anodized models will be available ($335)
2011-2015 Polaris RMK 155-174"
2012-2015 Arctic cat proclimb 141-174"
2014-2015 Yamah Viper 141-174"
*Fitament*
Will work with any stock or upgraded shock packages in the OEM skid
Fits standard-RMK, PRO-RMK, and assault (155"+)
Fits M, HCR, LE, Etc
Fits with stock, or IceAge Rails
Not compatable with Skinz A.R.C.
Can be used with Zbroz K.I.S.S. coupling blocks
Please contact us if you have any accesory you are concerned with it interfering with.
We know that durability is key, so we made sure this part could take a beating. We start with two blocks of 6061-T6 Aluminum and mill the 2 peice body. We then head the lathe and turn down the two 7075-T6 Aluminum shafts for the kit to pivot and ride on. We then slide in the spherical bearing and assemble the kit. This kit not only looks good but is absolutely tough as nails.
Many riders complain about the "wandering" or "loose" feel the T-motion has. We chose to relocate the pivot portion to the lower pivot shaft to help aleviate this as much as possible. Now instead of the rails rocking side to side as they pivot, our kit allows the rails just to rotate. This helps maintain a more planted feel while still reaping the rewards of the flexable rear suspension. This also allowed us to add slightly more pivot while keeping the track properly aligned in the tunnel.
