So why not drop the little line into some kind of a safety bottle rather than just leaving it dangling there??
Do not run your breather tube where MPI tells you too. You will pull in moisture and ruin the fluid in your charger, then they will not warranty it even though they specifically tell you to place it there and have been told multiple times it's an issue.
The fix that we have found is to drill the subframe just above the top front cross tube and insert the breather in a downward position.
There, the breather will not collect any moisture and you will not void any "warranty" they provide. This has been a sore spot with me for a while and have asked that they change their directions with no prevail, kinda frustrating seeing as its been years now and still hear of people getting fluid in their chargers and losing them.
We all know that the nytro collects a ton of snow in the nose of the sled, even if the breather is farther back or even extended to back by the block, moisture travels down and once the oil in the charger cools it creates a vacuum and will pull fluid or even vapors and over time will create damage. So please any and all consumers of this product please redirect your hoses into the subframe, it will save you a major headache.
PLEASE DO!I might post my turbo install.
oh ya, all snowmobile problems can be solved with the proper application of
