very nice i went over the bars last year and was very lucky i didn't slice my leg wide open on the mountain..... i will be making this change for sure
Only thing I don't like that I'll figure something out for is the bolt under the boost gauge. I left it out for now, otherwise you have to pull the gauge to get to it so you can remove the hood. Also leave some slack in the boost tube to get it on easier, the barb fitting in the boost gauge sits inside the hood and you need to slide it on before you slide the gauge in.very nice i went over the bars last year and was very lucky i didn't slice my leg wide open on the mountain..... i will be making this change for sure
No spare, kit had about 30 miles on it before today but all at sea level. Guy with a Silber pro re-calibrated his wideband and it fixed the his issue, he had the same as I do. I have a different wideband though and is supposed to self calibrate.You could have a bad o2 sensor if you have a spare try pulls switching that out
Tps sensor, nothing wrong with the impulse. Now for the 2 hour drive to the dealer to get a sensor and put it together in the trailer tonightYou could have a bad o2 sensor if you have a spare try pulls switching that out
Sent from my Nexus 6 using Tapatalk
Going to 2 Mile doo right away in the morning to get it calibratedYou will need to have buds to zero the new tps.
Finally some snow!
