So true, I really don't want to play with fire no more, I'm happy with 6/7 lbs boost, heard another tss went down last week with big boost and broken rods as well..
That is why we dropped boost to two clicks from the lowest boost setting, but it still hit rev limit on clicker one..
I'm tired of replacing reeds and just want a primary setup that will hold rpm under 8000..
Fred how much boost you plan on pushing this sled to? You worried about throwing another rod? My buddy turned his TSS down to 6psi this year and finally got it to stay together for first time in three seasons.
You guys talking about running 10psi or more I would be careful, the Etecs don't seem to like it. Just a warning these motors are not cheap to replace. The Etec's make so much power on low boost I would set it at 7psi and be happy IMHO.
Maybe Paul has a lot of timing pulled on the top end though so maybe that helps?
Thanks for your setup info, I very much could be setting it up the same way, your gearing I bet made a big difference as well.. Wait to have DJ get back to me thanks
Backcountrypro
03-29-2015, 01:01 PM
I run Toms arms on my T-Etec. Paired his arms with DJ's ramp and helix.....for me it works great. I am running a 160-290 primary. Dj's ramp and the ramp from Tom's look very similar.
Yes on gearing up. I went from 19:51 to 23:51. You make big power you need to gear up to take advantage of it.
This is on a Turbo Perfomance kit.
Backcountrypro
