Anyone having problems with water in electrical plugs causing sled to run on two cylders at low rpm and excesisive amount of oil purging from breather on canister
What elevation are you running at and what clutching are you using? STM? SHOCKWAVE?
I have found the supreme tool and machine weights loaded to 76 grams works well with a cat green secondary spring and shockwave about 1.5 turns out or a 45 degree helix or 47. Im at sea level to 4k feet though.
I'm running 16 psi @ 9000 to 11000 feet. I have SMT weights, 14.5 rollers and shockwave helix turned one rev out w/ cat green spring. Weights have 2 tungstens in the heel and two washers at the tip with green white green primary spring
I'm not sure what wieghts I have, there what Paul sent me with the kit. Riding at togowotee pass.
