impulse nytro map sensors
R
relentless rider
I just got an 08 impulse nytro , with the 2860, and closed loop fuel system.
question is, there are 3 map sensors and only 2 have vacuum lines should the 3rd one be receiving a vacuum signal?? The problem is it wont idie and a very bad hick up getting onto the throttle, I did a boost leak check fix the one leaking fitting on the bottom of the intercooler and than grounded the tps to the battery and that seemed to help a lot thanks for any help!
I removed my standalone for a a Boost It, but if I remember correctly there are only two sensors, one map and one barometric . The barometric has tow hoses the third nipple is left open.
