99% of all turbo problems I run into are related to fuel pressure, boost leaks or vacuum lines not routed correctly. It only takes one wrong tee or loose hose to ruin the whole system.
We run big injectors, heads, porting, Q16 fuel, E85, sea level, 10k, sand , snow, morning , night lol Are stuff runs just fine at idle and transition onto boost. Anyone that says big injectors cant idle or work simply dont have it set up correctly.
I would start from the beginning and double check wire connection,updated ecu, vacuum lines, boost leaks, fuel pressure, throttle safety switches, timing etc
