B
branix
lcd only without case.
last row will be replaced, on a 2 stroke you do not need oil temp. instead we will have barometric pressure
there is also a LED for OIL F/E
Wyo you said you want to see what the ecu sees. I am not sure what branix's ecu is going to see but his optional display can show: RPM, MPH, BOOST, EGT, WATER TEMP, AIR TEMP, ALTITUDE, HP, FUEL, OIL, O2, TPS, INJECTOR DUTY CYCLE, MAP 1 or MAP 2, KNOCK SENSOR, SENSOR FAILURE, (taken from push's website.) With all this info it should be VERY easy to tell when you have a problem. But this is all based on the info for the prototype so we will have to wait and see if the production units keep all the features.
Dakota Performance has a picture of the prototype display.
