So should I just freshen up the clutch and run this mother? I don't know if I can swing the cost of a big bearing upgrade. Maybe now that the wife has a job though...It could have been .005 from the FACTORY. LOL
If I had the dough I would probably go with an indydan lower end as he warrantee's it. But I am a broke hoe
I've done tons of reading on Dan's crank mods and while it would be nice, I can't afford to spend that kind of money. I was on the edge of selling it/trading it in and buying a REV but not having a payment takes precedence over a newer, fancier sled.Good move....Clean er up and run er til she pukes. LOL
BTW, Indy Dan does NOT do wide bearings...and he'll give you all the info about why as well.
thats what I was thinkin the end could be off the chartsyou need to check the run out on the seal boss but if it is at 5 on the end it will be around 2 and a half at the seal.
Just some background info to help fill in the gaps...
I bought the sled spring of 07 with roughly 1800 miles on it... has about 2400 miles now.
PO had an SLP single and clutching on it, but took it off and swapped his buddy for stock parts when he decided to sell it.
I have the SLP torque arm and push stop but still running stock motor mounts.
Engine is (or at least was last time I checked) perfectly aligned.
I did blow a belt last season... it was on the trail but I had the hammer down.
I have the primary off right now and I need to read up again on how to check it over to see what needs replaced... Indy Dan told me I'd be better off to **** can my primary and just buy a new one.
Mountain horse,
Where do you recommend getting a primary clutch balanced? There used to be a place in Spokane, but I think they got out of it quite a while ago.
Thanks
