I hate this sled.. No its not that bad
M
micfly007
New member
Two problems actual three the lack of snow. One of the real reason is that the idle is real high i did a handle bar riser and throttle extension is there a an adjustment or is it the tps? It is just one constant rpm so i don't think it is the tps from reading other things on this great form site. Second have a collant leak under the engine do i have to pull the engine or is there a better way to get at it? Also is there a problem with some cooling parts under neath?
Ohya its an 2005 rmk 900
Follow the throttle cable from the throttle lever towards the engine untill you find the adjuster, it will be inside a small rubber boot. Peel back the boot and adjust the cable untill you have a little slack in the throttle lever.
As for your coolant leak if its coming from the back of the engine under the water pump its probably the mechanical water pump seal.
X-2 when replacing the mechanical seal make sure not to touch the carbon they are very delicate. Good luck
