-- I like the Tial external wastegate due to the relatively uninterupted exhaust flow over the turbine wheel. Apparently this allows to run 3lbs less boost for the same power compared to a non-Tial(Tial 8lb = 11lb non-Tial). Tial = more power per lb of boost plus quicker, more efficient spool. So less boost = same power = less heat = less octane = less money for high grade fuel. I like simplicity of some of the kits also.
That would be great if it where that simple, I would have to see it to believe it though. Octane wont matter, they will all put out about the same power on the same octane weather its 6lbs or 11lbs if tuned right, but may depend on charge temps too which the better turbos should run lower. Its just a matter of physics.
My sled at 6lbs will run with some other kits at 8lbs (thats right around pg deto limit on both) so if your telling me that with a tail I would have the same power at 3-4lbs theres no way, all though I might have more at 6lbs with a tail I don't think it would run like it does on 9lbs. But like I was saying I don't even need 12lbs and less is more in my world.
