Personally in my mind I think the 2 stroke cycles more than 2 times the amount of air, when the piston is down all the ports are open which allows the boost to clear the cylinder as well, so not only is it firing twice as much because of the 2 stroke instead of the 4 stroke it flows through the engine more without valves shutting.
I'm still not quite putting this together completely(i might be but want to be sure), from what I understand they are taking the 2876 which is the 28 housing on the hot side and a bigger intake side. But when you say .64 I have no idea. between the 2876 and 3071 could someone list what it is, i e which side you are referring too, then the stock size vs the modified size, so if your saying .64, what was it before and are you changing the inside only or the whole housing. Get specific with all numbers and changes so I can piece it together in my mind and know I understand. If someone would do this I would greatly appreciate it. I don't have the option to get hands the way I need to.
I even thought people where starting to use the 3076 on the m1000
