6 belts?????????
On the average, 6 belts would last me 6 years!
Sorry but laughed my a$$ of at the 6 belts....
Hopefully you guys figure out the 850's.
I remember you being a belt blower with the PC as well?
Maybe you just ride to F'n hard?
With proper clutching and clutches that actually work, the clutches will never get hot enough / slip enough to blow a belt, regardless of how much / how hard you ride.
But if you want to keep the lesser companies in business, keep doing what you're doing.
What exactly do you mean by saying this?
Cat and Doo are well known for clutches that don't work very well / the Cat (Comet) imitation of the P85 is fragile and detonates (Spider Failure, typically; even the high end billet spiders) far before it should. Their newer stuff may be better, time will tell.
The Doo TRA? grips well off the line but losses grip on the belt as it shifts out (when they are actually making HP). Time will tell with Doo's newest Primary.
As a note; The factory clutching from all the manufactures leaves a lot to be desired. The modern thinking is stiffer springs heavier weights and steeper helix angles, which results in the clutches fighting each other and little of that that fight goes to actually grabbing the belt. Which results in slippage and defeats the functionality of the CVT transmission.
The CVT is far more efficient with lighter weights, softer springs and shallower helix angles! And yes with the right combination and balance, your belt will not slip (ever) regardless of the snow conditions or how hard / long you ride, and you don't need additional venting![/QUOTE
When is ski doo gonna hire you to fix their problems?
I'm currently employed, at a job I like very much. Besides I could not live back east in the flat lands with all those people! Besides I don't think that the French Candian's are very open to other opinions / ways of doing things. Additionally it would likely be a pay cut, and to have to think about and touch Doo Doo everyday would be too much. LOL
14 gallons of spare fuel....check
6 Belts.....check
12 Beers.....check
Overnight gear.....check
heckitall Pills....check
im not quite sure the ratio of 6 belts to 1 roll of TP is a smart idea.
With that many belt changes id also need a couple more pairs of Bibs along with some wipes and at least one more roll of TP. LOL
Oh yeah, be careful with those wipes in sub freezing temperatures.... Don't ask me how I know what a frozen wipe on a bare a@@ feels like.....
Hope your belt issues get resolved soon. Sitting in the shop sucks with snow like this.
Everyone's an engineer��
Never blown a belt on my 2010 doo. Clean clutches every 300mi and replace rollers, pins, center cap and bushing every year. Sometimes maintaince is the easier then having the dealer work on your ****.
Everyone is an engineer.... Except I am fairly sure Loudhandle has a patent pending on a clutch design?
Actually it is a complete CVT with none of the weight penalty of the current versions. I designed it small enough to locate it all inside the drivers for centralized weight and to utilize that wasted space. No belt to slip, Gates Poly Chain Carbon (or Mitsuboshi Giga-Torque GX) from crankshaft to driveshaft centerline. The magic all happens inside.
