I had an 04 2500HD Chev with the 6.0 gas motor, extended cab, long box, 4x4. With me in it and a full tank of gas it bent the scale at 6420. The gross cap of that truck is 9200.
A little meth...er...math says it has 2780lbs worth of payload available.
Unless you ride the newest lightest stuff out there your pair of sleds will be 1200lbs together. add your buddies fat azz-200lbs, gear-100, sled deck-500, an extra 20 gallons of gas-120.
All of that adds up to 2120lbs
2780-2120=660 lbs from MAX CAPACITY. If you have a Duramax you are right at the trucks capacity. Any half-ton is way over loaded.
My current '96 Powerstroke is over cap with all of that weight.
Its not the fact that the trucks dont have the power to pull it. They lack the important stuff like brakes, frame/axle strength, as well as the trucks own weight (lack of).
I think this topic has been beat to death
In summation
Running a deck on a half ton can be done. However, it is not recommended.
3/4 or 1 ton is preferred.
If putting a deck on a half ton, air bags are mandatory IMO. Also, have the HD payload or towing packages are nice. For instance the F150 with HD payload gives you an 8200 GVW. My 11 F150 weighs about 6000 lbs. That should cover two sleds and an aluminum deck.
However, one should also consider the legal part and look at the GVWs and curb weights.
Technically if you went off specs, my 11 F150 has a higher payload then my 01 or 03 Cummins.
My 11 F150 has a 7200 GVW and weighs 6000 lbs. = 1200 lbs payload
My 03 2500 Cummins had an 8800 GVW and weighed 7900 lbs. = 900 lbs payload
However, the comparison in what you could haul is huge. The Cummins did not sag at all with an 800 lb ATV or 3 dirt bikes in the back. Or towing a 4 place enclosed.
I run about 20 lbs in my airbags in my F150 to get rid of the sag hauling the same load as with my Cummins.
Technically if you were in a accident with the Cummins, you might be held liable though.
So, you guys with diesels should check your weights. I wouldn't be surprised if your just as far over with a 3/4 ton diesel as you are with 1/2 ton.
If you have the 1 ton SRW with 9900 GVW you should be all set or a dually no problem.
If I was to run a deck, I would buy 1 ton to be safe. No question about it.
I think my F150 would be fine with a deck but I really have no desire to run a deck.
Just food for thought.
Food for thought...
I dont know where you live but word in BC is that there will be a zero tolerance this year to overloaded vehicles. I went to Squamish last weekend and ther was a major roadblock between 100 mile house and Clinton. Every car, truck, minivan or what have you with a deck or trailer or combo of either was pulled over on the side of the road. RCMP, CVSE, Fish and Wildlife and any other law enforcement agency you can think of was there. It was a joint effort looking for payloads, poachers, seatbelts, DUI , etc. I wouldnt risk anything other than legal if you are coming to BC this year.
On another note, I had a 96 GMC Z71 S/B with airbags and a deck and 2 98 summit 670s were barely legal....had room for a passeneger that was under 100kgs.
