How many horse per pound of boost? I was told 7 horse.
Is their any difference between that number from 2 to 4 stroke?
Matt
yeah, i beleive its a semi exponential sorta thing, cant guarantee it, but as pressure increases, the amount of air being moved increases at a slightly higher rate.I thought that more boost was not the same across the board.
Lets say you start with 8 and go to 10...you gain about about 15lbs of boost with that 2 pound addition...
BUT start with 12 and go to 14 and you gain much more like 20 right?
How would you gain 15 lbs of boost going from 8 lbs to 10 lbs ?I thought that more boost was not the same across the board.
If it is a good kit and everything is sized properly and the over lap between the intake and exhaust cycle is not crazy, a motor that starts out with 150hp stock will make 10hp per pound of boost. A motor that puts out 75hp stock will make a extra 5hp per pound.
Keep in mind that is not all the way across the board, a 150hp motor at 3psi will not make 30 more hp, and at 25psi it will not make 250 more hp. Most kits are designed to run at 8 to 15 psi, that is the sweet spot and everthing in the kit should work together at that power level.
I thought it had to do with atmospheric pressure. Atmosphereic pressure at sea level is supposed to be 13.5psi or something so I thought in theory 13.5lbs of boost pressure should double your hp. ex. apex turbo 150hp stock 300hp 13.5psi 450hp 27psi?
