MCSD409
How is the lag on the HM turbo? To date I have not even considered a turbo for my riding for the following reasons.
First, I live and start every ride at sea level. So if I run much boost, I'm paying the premium for AV gas or Race gas and really don't want the additional expense on my every day sled.
Second, When I get to ride I want to ride, not fiddle fu-k with the damn control box. I'm a family man now and my fatherly responsibilities take presidence over my personal recreational activities, so I don't get to get away to ride nearly as often as I used to. So I'm glad the Vipec and all Shane's R&D is paying off.
Third, While locally there really isn't that much tree riding, I refuse to give up having instant torque and acceleration wherever and whenever I want it! Some will say you can learn to fiddle fu-k with the throttle and minimize the lag but I would much rather just grab and go! At our local hill climb there are always the automotive turbo guys that putt thru the gates, if they can even get the sled halfway up and then try to make up time I between the long gates. Most are lucky to make it past halfway up.
Which leads me back to my original question. Does the Aero start building boost lower ( pre or right after engagement) than the automotive turbos? Is it usable and friendly on and off throttle? Are there any dead spots? If so what RPM? If I want to turn up the boost for a weekend with the boys, what gas is required and do I need to reclutch for the extra power? Thanks for your time and thoughts. Hope this isn't too far off topic.
Hopefully I can help you out on this:
I tested alot with Shane and Levi last year and was the original guy that started testing in the US with the Vi-pec on the Pro RMK actually I introduced Shane to it.
1)How is the lag? The Lag on the aero is barely noticeable with the standalone because of such precise fuel and timing control I can honestly say that its better than a stocker, the crispness and response is like no other turbo that I have ridden to date.
2)On/Off Throttle-- The on off throttle is right there, tight trees there is no issue the only issue I see alot of with my customers is they originally want 10-12 psi boost and end up turning it down because the power is way more manageable in the trees. No blurping,gloating or stuttering. The only way the sled will ever and I mean ever stutter is when you wheelie and slam the exhaust full of snow Thats it!
3)Dead Spots- GONE FOR GOOD! No more wondering if you can blow down in a creek because it might bog or cut out on you. Folks thats GONE!
4) Turning up boost: The base 190 kit is setup to run real close to a safe injector duty cycle with maintaining max boost for elevation. What this means: If you ride 1000ft elevation it might run 5 psi boost and as you go up in elevation the ebc will bring the boost up to match your clutching, injector cycle etc to maintain the same HP all the time. The max boost on stock injectors is around 8 psi at 10000Ft.
5) Aftermarket Boost setup (high Boost): I am not going to reveal any info on how to do it but I will tell you its a 5 minute job to go from low to high boost once the bigger injectors are installed, very clean and easy process.
Just some neat info for ya:
I tested the last time in May with Shane at 7000ft elevation around 40 degrees F outside ,sled ran perfect brought it home and fired it up a couple weeks ago at 1667 ft elevation and 83 Degrees F. The sled ran awesome for the little bit we ran it on the dyno and the grass at 100+MPH
Any other questions feel free to ask Ill try and help
Jake
