B
big_red1a
Hey guys have a 10 nytro mtx looking at 3 possible turbos. I plan to install myself and do not want to spend the winter wrenching. i make it to the mountains a few times per year and mostly ride meadows and trees but occationally need to do some climbs to get to these areas. I never see myself as a chute climber. I will also ride back home at low altitude.
A.I do not want to upgrade later, is 180 enough? Will it outperform all current stock 800's
B.Is the larger Impulse standalone reliable?
C.Is the impulse very ridable at slower speeds in the trees and meadows or just point and shoot?
Here is what I have found, feel free to correct agree/disagree or add to these
1.Mcxpress 180hp 6psi+ auto altitude ajustment to 180hp $4479Cad
easiest install , no heat issues low cost, no head shim, very popular well tested, only need to set up clutch once (adding weight to stock arms) due to altitude ajustment in turbo, snow to air tunnel cooler may save weight, have dealer in home town, yamaha dealers seem to install the most, seems the most reliable, ships free in canada
Cons:No tunnel dump or Bov, weight of stock header and aftermarket muffler, add boost gauge? mid mount turbo lag?, does not correct yamaha exhaust donut issue, cut and weld oem exhaust? have also heard of headers cracking. ice build up at rear air intake from heat of exhaust? the 90 snorkle may help but what happens with tarp or rolling the sled? smallest (stock) fuel capacity. still may have ice build up in tunnel
2. Ulmers 6-8-10lbs high alitiude 180hp 8.5gal fuel $4599usd summer price
cast manifold, front mount (minimal lag), bigger gas tank, great service, locking header bolts, may correct exhaust donut issue??? 8hr install, air intake is protected from snow but may gey warmer air from undel panels Cons: heat under fuel tank? vent kit required, add gauges air/fuel, boost, water temp ($455usd) add clutching($300USD) not sure how clutching will react at differnet alltitudes/boost levels Add blow-off valve($300USD) must change exhaust (add tunnel dump exhaust maybe option ???) Not sure about having to reconfigure when changing altitude??? manual boost gauge required ($109usd), weight of header and turbo unsupported still may have ice build up in tunnel?
not sure if there is any power advantage over the mcxpess system due to the limitations of the stock fuel system
3.Impulse 17psi 285hp 10gal fuel $6775usd
no user ajustment gas and go, front mount with no heat on gas tank, biggest turbo, includes tunnel dump exhaust into front of the tunnel, (May correct tunnel icing??) Air intake and exhaust in the most effiecent loction for quick boost, rear tunnel open for storage, includes hudge blow-off valve, fuel weight moved to rear for more ballance, 10gal fuel capacity (largest), Most power with no need for future upgrades, stand-alone fuel system, Boost can be dialed down to 12lbs
Cons: cost, head shim required, retard timing, most difficult install reqires removing engine, clutch realignment ect. vent kit required, LOUD, no guages ($500usd) add clutching/gearing/shockwave ($550USD)shipping $300usd, does the headshim lower the bottom end power required for trees and slower technical riding or are you already into the boost??? I do not think that the stock skid will keep the skis down with this kit and we all know that this can become a very expensive snow ball (rear skid, track, drivers, tunnel.........)
The first 2 kits could be removed and the sled put back to stock. The third setup would not be worth removing and selling seperate.
I really like the lower boost kits but want to have enough power. I am also a bit concerned that with a 280 kit i will not have fun riding with NA sleds in the trees and meadows.
I am hoping that many of you have 1st hand experience with these options, if not i still value you opinions and ideas.
Thanks for you input and and please state if you are speaking from experience!
_________________
08 Apex LTX GT 40th 136" cobra,198 gd,extros, simmons,scratchers,triplepts,7.1revalve,powder coating,gps,snoweliminators,13mm sway, oil-lights,vent kit,grease zirks,OFT steering
10 Nytro MTX SE 162"
_________________
