Skinz is using CHROME MOLY.
So that is not the issue at hand.
It's kinda hard to tell from that pic but they don't look like high deflection rod ends but I could be wrong, usually it'll have a collar built right into the ball, also all Cro Mo is not created equal, there's a reason why 1 brand costs $70 an end and the other is $13. Food for thought.
M5
What size is the shaft on the rod end. Timbersled uses 5/8" and I've never seen one of his break.
As of today, they are stocking an upgraded even stronger joint from a different company while the analysis takes place.
So that is what SKINZ just sent you as a replacement?
Or is that something you bought on the open market??
<table width="100%" align="left" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td valign="top" width="3%" align="center">That is not a high misalignment joint so at full travel it will bind tansfering the force to the bolt. Something like on the link below is what is needed. I can't remember off the top of my head but the Nytro travels 15 -16 degrees. I measured it once but the memory aint what it used to be.
http://aurora.thomasnet.com/item/br...lignment-series-male-rod-ends/hxam-8tm-500-2?
m5
m5
First watch this:
http://www.youtube.com/watch?v=wOvNhHBuOTI
While I hate to admit it, that was me at the controls. I was running one of the first prototype Concept front ends test riding for Skinz. The sled rode out the rest of the day after this incident. A small wrinkle in the lower a-arm, as well as, a bend in the heim joint was later discovered. Considering the impact, I believe that the front end held up a lot better than I expected it to. I was surprised to see the ski still attached.
The heim joints on my prototype front end seen in this video were the same ones that were supposed to be supplied with the production version of the Skinz Concept front end kits. It now appears that the production ones that were supplied are not up to spec and everyone is vigorously trying to find out what is wrong.
There is no problem with the vertical travel and the ability of the heim joints to align themselves properly throughout the travel of the suspension. It has been checked and re-checked.
The problems are sporadic. However, it looks like some of the heim joints may have failed prematurely. Skinz has dumped their original vendor and will replace the original lower heim joints that were shipped with the front ends free of charge.
-Crash Test Dummy
aka scmurs
So to be clear, your Eye bolt, the one that attaches from the end of the lower A-Arm to the spindle broke off just like mine? As seen in this picture...
To clarify, my A-Arm is 100% unharmed. I haven't fixed it yet but I have a replacement eye bolt and I'm hoping it won't be too big of a pain to get it out without messing the threads up.
This is how i fixed it. Had to ride out 15 km like this.
