I think I just fixed mine
So after calling Boondocker today, I found that my kit was installed wrong (Not by Boondocker). My turbo oil pump and secondary fuel pump was getting its power off the headlight circuit (red/black wire coming from CCU). It should be getting power off the circuit to your gauges (red/blue wire, same circuit as the one connected to fuse). Here is an attached schematic:
https://docs.google.com/open?id=0B05A9arP11u1ZjliNTVkZTMtYjZhZi00ODRmLWJkNjUtNjE4M2IwNGQ0NWVj
At first the techs and I at Boondockers thought it was my CCU crapping out, so they had me test voltage coming out of the CCU. On my schematic you'll notice that you can 14.7V at three different places coming out of the CCU. One goes to headlights, one goes to gauges, and one I think is the tailight circuit, or maybe reverse circuit (purple/black wire). Obviously the headlight circuit isn't good to use because the lights drain a lot of power. The black/purple circuit scared me a little because if that is the circuit that powers my reverse, and since my reverse beeper is goes off when the beeper is plugged in, something funky is happening with that circuit. So I decided to splice my turbo oil pump and secondary fuel pump into the circuit Boondocker recommends (red/blue with fuse).
Anyway i cut the power to my turbo oil pump and secondary fuel pump from the headlight circuit, wired it into the gauge circuit and my fuel pressure jumped back up to 42psi from like the wavering 32-38psi it was before and my turbo oil pump started pumping strong. My gauges still work perfectly, headlights are strong, as far as I can tell on the stand she is going to work!
Note, I am premixing, so I don't have a stock oil pump hooked up, maybe saving a little power from the system...
MikeM1000, if I were you I'd unplug the main bundle coming out of the CCU but leave the yellow wires coming in intact. Use a voltage tester and test your voltage coming directly out of the CCU. If you aren't getting a strong 14.7 (mine jumps from like 14.5 to 15) coming out of the red/blue/fuse circuit, it might be time to get a new CCU, or possibly a stater. If you are getting 14.7, there has to be some short or something in your system. Because right now that circuit is running my normal speedo, Koso EGT gauge, turbo oil pump, and secondary fuel pump- seemingly without a problem, I think 14.7 is enough to run all that. You could also try running just your secondary fuel pump off of the red/blue circuit, and maybe just tap your turbo oil pump into the headlight circuit. My sled surprisingly ran fine for a about a year with both my secondary fuel pump and turbo oil pump running off of the headlight circuit, but now that I think about it my headlights were always a bit dim. A plus about running on the headlight circuit is that if you loose your headlights, you know your turbo oil pump isn't running as well... I am running the stock turbo oil pump that came with the Boondockers Race Gas in 2008
