I have an 146 XP and it still blows belts 5 belts in 550km. So what have you guys done to improve the belt issues. Also has anyone tried the Goodwin Industries jackshaft conversion kit so that you can use the old secondaries / team clutches.
Ok I just spoke with a doo engineer at the Minneapolis Ski-doo show...
I did a post on the dootalk in the XP Mountain forum with all the details..
Here is in a nut shell from the doo engineer
The 377 is a REALLY good band-aid fix.
The issues of blowing belts is the primary on some sleds is out of wack. There was a issue with the supplier of the cast pieces that hold the engine in and it is out of spec.
Please see
http://www.dootalk.com/forums/index.php?showtopic=218889
for more information
No issues with proper settup....which is NOT the factory settup. And alignment of course, which is dealers responsibility. Make sure alignment is correct and primary rollers and bushings are in good condidion (both are only good for 4-500 miles). PM me for settup info.
I've had a few XP's in the shop now and every one that has come in the engine is out of alignment,the one was blowing the new 377 belt,it was way out,so I aligned the motor as much as I could and the belts quit blowing and the performance got better.
I went into the Ski Doo shop and he starts telling me that they're supposed to be out like that, it's way they come.
The left rear motor mount needs to be slotted,or the rear clutch needs to be movable.The couple of guys that have the secondary kit have perfect alignment and very little if not zero belt issues.
I have produced a kit that will fix your belt problems!!!!!!!!!!
Get the details @ the link below
http://snowest.com/forum/showthread.php?t=69971
waita go linc, i always wondered why you spent so much energy bashing ski doo, til i found that you owned a yamaha dealership, now if they are so bad and you learn how to dial them in, think how much money you will make
