R
XP Belt trouble? I got the fix!
QRS SHIM KIT
In testing, this kit has shown to reduce belt temps up to 70*f, increase belt life and provide more consistent RPM's. Between my personal sled and the 3 different test sleds have shown zero belt wear with a total test mileage of 3450. Test sleds where a 08 TNT, 08 MXZ-X800R, 08 Summit 800R run @ 1000 – 10000 ft elevations, aggressive trail riding as well as mile after mile of WFO powder riding.
The QRS shim package consists of 5 bearing shims and 3 spacers to support the inner race of the upper chain case bearing. With this package you will be able to shim the secondary 2-5mm and have the proper spacers to support the upper chain case bearing and prevent any oil loss through the upper seal as well as bearing failure due to unnecessary side load.
Simple 20 minute install.
$45.00 shipped in the lower 48
$52.00 to Canada and AK
QRS SHIM KIT
