MotoTrax Questions and Concerns
Hawkster
8,196
6,413
AK
Well -------- now that it's documented I'd give that all thread a custom bend so you can at least ride .
K
Sep 9, 2013
987
394
Bend, Oregon
I can't really, because that is how you adjust the chain tension also.
I thought about reaming the hole out but that wont work either because when the nut tightens down there is a flat spot the bolt head and nut go on the adjuster so it would go right back to being angled all crazy.
Mar 8, 2008
70
It needs to be able to slide freely in that slot.
I'd ask for a refund and go rent a snowbike a couple times. Then get a 18 kit snowchecked when you find one you like
K
Sep 9, 2013
987
394
Bend, Oregon
Did you try to flip the round bar over
Yes. doesn't fit its been welded at a clocked angle or the machining is wrong... Is my conclusion.
Mototrax wants me to take it to my dealership on Monday now...for their mechanics to look at it ( they will come to the same conclusion I have I guarantee )
Things I tried.
1. Removed the threaded bolt and the nut completely, put side bolts in without the threaded bolt as a test. that fits fine.
2. with side bolts in and the threaded bolt out, tried putting threaded bolt back in. will not line up it cannot thread back in.
3. Removed the threaded bolt from the Original bulkhead and tried it and the round bar on the new one. wont fit...same problem.
4. Flipped the round bar around and tried 2 diffrent round bars.
Tried it like this to make sure without the threaded bolt in there it would fit... well the bolt wont go in, and i started cross threading it trying.
For Refrence, here is how it is supposed to look.. this is on my ORIGINAL bulkhead. No mototrax, my bolt is not bent. I tried both bolts I am not an imbecile. Putting a bolt through a hole is not a difficult thing when the holes line up lol.
H
Jan 24, 2014
157
156
CRANBROOK B.C
ITS A TIME BOMB
If you have not had problems with this track system you will.
Sorry to see you go through this KTMDirtface
Dealers get $75 /hr from Mototraxs to work on all these problems I think anyone that did their own work on these tracks should be entitled to the same $75/hr rate for warranty work.
SEND MOTOTRAX AN INVOICE
L
LFM2
1
7
3
Seriously, I wish you guys would give this a rest. Have a look at the Member Sled Builds forum and see the ingenuity of the members of this forum. If you need more than a couple of minutes to deal with this little bit of misalignment then you should send the kit back and probably get out of the sport. You obviously couldn't deal with a breakdown in the wilderness which could cost you your life.
There is nothing that this company can do that will change your opinions. I'm sure that many others recognize it too. I for one am sick of hearing about it.
K
Sep 9, 2013
987
394
Bend, Oregon
Are you referring to me?
Yes I could do some barnyard shop hacks to make it work.
But for ~$5k I kinda expect to be able to at least mount it without getting out the angle grinder and dremel.
Thankfully mototrax being very responsive and helpful and still trying to take care of me. They genuinely try to help. They seem to have some quality control issues of some sort, and I seemed to have had the worst luck ever and got the brunt of it and it ended up on the forum. It unfortunate for them hopefully they learn from it and clean up the mistakes, but its not my problem.
Its going to the dealer tomorrow morning and one way or another I will be taken care of. I don't know the options for me yet, one is that mototrax will take care of it. the other options with my dealer are up in the air I won't know till tomorrow.
dooman92
742
238
Your first post? You appear to be a plant from Mototrax. We come to this forum to share information which includes good and bad experiences. What snowbike kit do you own? Have you purchased a kit you cannot ride?
D
Feb 23, 2017
61
42
18
Cascades
So let us get this straight… You joined the forums in February of 2013 and this is you first post? So for 4 years you have been quiet but now all of a sudden you can’t take it anymore & you have to say something? wow.
Well, I for one definitely want to spend $4k+ on a product that doesn't work. See, I like to give my money to other guys to give me things that don’t work so that I can use my ingenuity to fix them later. Yesterday I bought a $200 custom bucket that had a bunch of holes in it, I'm going to use my ingenuity to fill them in later when I'm out in the middle of nowhere, what a score!
I mean, who expects bolts & holes to align, that is flying fairy expectations there!
:juggle:
M
Feb 21, 2016
663
158
Bend, Oregon
The kit is sold and advertised as a bolt on kit, thus meaning there should be no modification to the kit or ingenuity needed for the install, bolt on and go. It's a pretty simple that the kit pictured above had some serious issues preventing that.
And FYI - using anything mechanized in the "wilderness" is a federal crime.
L
Nov 18, 2014
164
54
CDA, ID
Im a pretty mellow rider, ski hardly leaves the ground and this is what I've found. My aluminum rear slider bushing is egged out and now it's beating the **** out of the lower mount. We'll see how the warranty claim works out...
HalfBrit
351
67
nw oregon
Hopefully they send you the spring conversion they are working on. I built a spring slider for my 2016 kit. Works great but I could definitely use a stiffer spring.
