TKI Belt Drive and Mountain Cat Drop Chaincase Install Questions
Chewy22
1,996
1,372
Montana
What hole are you in for the front arm? I have around 2'' on my Kmod, mounting bottom and back. Kmod doesn't even come with the caps though. With the 7 tooth last yr the bearings in my anti-stab gave out. Upgraded this yr from bdx setup to ice age anti-stab, better quality. I feel the 8 tooth won't put the stress on them though like the 7's
Stock 16 location in the front - lower rear. Middle hole on the rear drop brackets.
Frostbite
4,738
721
Eastern Washington
I have two holes in the front and one right behind it. I am guessing I should use the rearmost of the holes up front and the lowest rear hole?
Chewy, you say the middle hole on the rear....why?
scratley
885
325
Star Valley WY
Same as mine, my hoops on top of front arm may be an issue though, I have around 3/8 clearance to the track. might have get the hammer out. Should be able to get out this sun to see how it all works. But check your clearance up top. And keep an eye on the track wearing in that area
boondocker97
4,087
2,819
Billings MT
Lowest hole in the rear drop bracket has only added ski pressure on all the cats I've had and makes the handling worse.
