AKSNOWRIDER,
The Dragons were horrendous with snow ingestion. It was evident in piston scuffing. I understand the moisture problems. Maybe we are seeing more of this with the use of ethanol fuel. Transfer ports(intake) take up most of the bore. Why does it start close to the locating pins and the boost port? Loss of heat transfer, ring flutter, soft det.?
Ski-doo had a similar problem with rings and handled it with a change in supplier and ring composition. PI needs to do the same. What ever the cause they need to get it fixed. In my travels, I have talked with or have been in shops from Montana to Colorado and Wisconsin to California and this issue is wide spread.
My personal sleds have not passed the 1450 mark without ring or engine failure. Use non-ethanol and oil pump cranked. Maintenance is not neglected.
My past riding also racked up 4-5000 mi. per year, sounds like we both get snowpox often. The cough just started again.
The local dealer had a customer fail a leak down test at 390 miles, and he was running 100/1 in his fuel.
I know of only two fix kits in my local and they don't have many miles on them. Sorry guys, I get long winded.
