Joe i knew i could count on you to suggest "water" vs. "chaincase oil"......Somehow i knew "oil" would be a word you would be able to attempt to pollute with your BS IQ.
Joe, nobody turns there sled 90 degrees and carves there sled at 38 mph.....And everytime you do lay your sled over your always going to loose trackspeed regardless of which gear you use.
If your going to test gearing you have to test on long flat trails where the TRA has the ability to acheive "overdrive"..... When operating the TRA in deep powder acheiving "overdrive" is not going to be possible.
Furthermore "staying power" depends on the effectivness of the "belt". As the clutch heats up under load the "belt" can and will loose it's effectiveness due to "heat" aka "heat soak" which is a common problem with the TRA.
Clutching/Gearing is only as good as the effectiveness of the belt.......*flyweights, *ramp angle, *spring force means nothing if your using a weak belt.
Many snowmobilers tend to beat the belt to death which is a no no when you want peak clutch performance.
OT
what's that old saying?
....paint everyone with the same brush just because he can't do it nor will ever be able to?
With 20:49, I did gps across a meadow in Turtle once doing 36 mph track speed - the gps said 26 mph. Had no prob carving the 163 in a 90 degree turn under full throttle, but then again, Im in shape.
This season I watched a guy on an apex do about 40 mph gps across a meadow, carved the sled under full throttle, turned a 180, happened so quick it threw him off the sled. (turbo apex was amazing)
'09 xp 163" stock gearing and my '08 163" with the 20 tooth. I have NOT found an '09 to out perform my '08 yet. I do have the camo extreme too but my belts are way cooler then the '09.
Rode with and '09 163" with 19 tooth gear and I have to be honest. Dissapointing to see that thing go. Does NOT work. If you climb in the steep and deep and like to boondock only go down 1 tooth. 2 is too many IMHO.
Chaz
How much better if any is it to put on a lower 49 versus a top 19 stock 09 rev.
I can only get 35 MPH on my donuts, OT what am I doing wrong?
Your not doing doughnuts in the meadow at 38 mph, your not fooling anyone.
OT
So does anyone have a 19t that will fit an 09XP 154? If not where is the best place to buy?
