PJ, I had a tough time pulling rpms with stock gearing. I went to the 19 and it just seemed to work better in the steep/deep. Power was right there all the time, I did a few other changes that could have played in this too but I feel on my xp the 19 is working best for me...
I guess it is hard to tell anything with gearing and clutching in this Spring snow. I am running the 19 right now and it feels as if I have lost some track speed. I am only getting 45mph out of it going uphill in the heavy snow. I don't want to go back to the 21 because of belt heat, I was thinking of splitting the difference and running the 20.
I had my 08 running sweet then I wrecked it. I know that the clutching is different on the 09 so I am contemplating putting my modified 08 clutching back in over the summer.
I've got an 09 146, 5000' - 7000', should I go 19 or 20???
If you do go to a 20 let me know how it works out compared to the 19?? Its is tough to tell in these heavy snow conditions though. I rode saturday in 3' of incredible fluff pow and went back sunday to half the pow and setting up quickly... 45 mph in the steep/deep is pretty good!! Many guys are happy with 40-42...
My clutching is stock... thats my summer project just not sure what to run for optimum performance??
19 is the ticket!!! Staying/Consistent power in all conditions.... Head to Head 19 gearing works best unless you want to race on flat land all day at top speed...
You are saying you only want to use 50% of your variable transmision (clutch face) This has got to be one of the stupidest statements i've heard. In any car or truck with a direct drive tranny there is much to be gained with lower diff gears and an overdrive tranny. Its self explanitory. The more "gears" you have the easier it is to stay in the power band. How has nobody else jumped on this.
I think what XP174 was saying is you want to run at a 1:1 ratio under your most common full load. This leaves you the overdrive ratio for the trail home.
Some are missing the boat here...if you gear down you drastically change the torque sensing range of the drive system which requires extensive tuning in both the primary and secondary to work properly. JMHO...good luck.
For what it's worth this is straight out of the new snow tech mag.
The Ski-doo summit xp 154 models came from the factory with 21/45 (2.14) gearing in the chaincase. This has been found to be possibly too tall for machines operated aggressively in deep snow or at extreme elevations. For these environments, changing the gearing to a lower ratio like 21/49 (2.33) like the 163" summit comes with improves the performance and drive belt durability. A 19/45 (2.36) ratio could also be considered, but is not as ideal as the larger diameter 21-tooth upper ( in combination with the 49-tooth lower).
I guess I have to agree so far, my 09 seems to work great.146 guys have 23/45 (2008) and 21/45 (2009)...IMHO the 2009 gear is spot on...BJ
Gearing down slows trackspeed.
OT
Just a reminder the whole gearing down theory has been over played by the the likes of BJ and others for years. Here's another thought....some of you guys should clean out your chaincase more often. Running clean oil can give your sled an edge as well.
OT
I think if I were to say something like that, it would be an embarrassing and insufficient comment on its face.Just a reminder the whole gearing down theory has been over played by the the likes of BJ and others for years. Here's another thought....some of you guys should clean out your chaincase more often. Running clean oil can give your sled an edge as well.
OT
