I second the armadillo bag, I have the 3 gallon one and it fits perfect right on top of my burandt bag. I use 2 of the pronghorn straps that they sell to attach it to the tunnel bag. It's very secure and will not fall off or even slide around.
just around the burandt bag? then rely on the burandt bag attachment points to keep it on the tunnel through the whoops?Long Titan straps are the most secure way in my experience.
You can run straps through the front lock & ride base mount, each running board side, etc. Just depends on how violent your access zone is.just around the burandt bag? then rely on the burandt bag attachment points to keep it on the tunnel through the whoops?
I ditched the t slot attachement hardware on my burandt bag when I had it on my axys. I went with stove bolts on the axyx and mounted it like that. On my boost some of the holes that were already in the tunnel lined up, i think i just drilled the second set and bolted the bag right to the tunnel with the rubber spacers from the original hardware.just around the burandt bag? then rely on the burandt bag attachment points to keep it on the tunnel through the whoops?
