no problem, i just know it works on a very logical basis, so explaining it makes a lot more sense then just saying, YOU NEED THIS NOW.So the main performance difference between the 2860 and 2876 is going to be a more linear boost and stronger top end with the 2876? I'll have to go to a bigger diameter charge tube also? And then up my fuel across the board or just in the bottom end?
Thanks! for the input skidooin.
most likely could run the same charge tube, i think all of the turbos discussed run the same 2" outlet.. i prefer bigger charge tubes etc. but the physical inlet/outlets on the compressor side should be nearly identical.. exhasut side is the same.
benefits = better in and out of the throttle. hitting it from idle comes on much smoother and to say there is a little more on top is an understatment.. i would make an honest bet that if your currently running say 10# that you will pull the same clutching at 7# or less and have a much more rider friendly powerband.
as for fueling, im not knowledgable to say exactly what it will need as it does vary with how your box is setup. but you will need to retune a fair amount for it. but im betting what you will find is its much less touchy in how its tuned. with the higher power on lower boost, charge temps stay down helping deal with heat soaking, etc, so your state of tune stays much more consistant.
