E
Einar74
Angermanagement890.
this is a info from RKT website. the link is at the bottom
There is no RPM change with this kit. The kit simply addresses the issues associated with the stock (OEM) Piston.
We will be offering this kit throughout the Summer and the following seasons.
Piston side loading is reduced due to our unique piston's weight. Yes, this piston is much lighter than the OEM piston and having a lighter piston will reduce piston side load pressures AND reduce the stress on the crank!
Less Stress = More longevity and more power!
We, REALLY, do address the OEM piston design issues with this kit.
No more "SLOPPY" OEM piston with poor piston geometry.
BEST PART: NO AFTERMARKET PIPE, Fuel controller, OR anything else is needed! We, purposely, designed this kit to perform using the components!
Once you have the kit installed.. YOU ARE DONE!!
Reliability is NOT compromised in any way, shape, or form and the cost is VERY affordable.
http://www.2strokeheads.com/Polarispistons.htm
