Rod Ratio
Hold on a Minute here, Lets not confuse things.
Pistons do not change rod ratios.
BUT, Piston wrist pin location....... ( be it vertical adjustments or offset from center ) does have an effect of piston life on certain motors depending on the bore & stroke and rod length.
But you cannot " fix " rod ratio with a piston.
A short rod is a risk.......... it allows for tight case volume & a very compact motor. There has been no-problems with 64mm stroke & very few with 68mm stroke.
BUT with the 70mm stroke the short rod has started to show its short comings.
