P
pura vida
So how many people have actually gotten out a 10lbs weight, hung it 16" from the rear axle and set the track tension as specified in the manual? I did and holly cats is that sucker tight! have about a 7/16 gap between track and hyfax which is what the manual says but this seems extremely tight. i sure don't have to worry about it ratcheting...
now i know that you don't want the track noodle loose and the track functions better at the proper tension. but what is the proper tension? i can feel the drag of the track when i get out of the throttle and i'm guessing i'll be going through more hyfax. this just seems like it is too tight, less efficient, and i am just using up extra HP?
or does the physics of the track under power change the equation so that it is most efficient at this tension?
does it matter that it is a powder claw and not the 5.1? i wouldn't think so.
has anyone found a tension that works better/more efficient than what the manual says? (since we all know polaris "always" is correct with everything they say!
thanks
pv
thanks
pv
