FACTORY AXYS RUNNING BOARD INSTALLATION ON MY PRO-RMK.
5.00 star(s)
7,950
6,710
7,950
6,710
Still need to tuck and pull the plastic in.
End result
Stock height bars now fit great.
I'm 6'2" and the bar height is perfect.
Sled is ready to be dropped off a cliff. :)
Bombproof
ditch1000
476
88
Fort St. James, B.C.
Your gonna lose 10 lbs of ice and snow; just on the drop brackets alone!! I'm thinking of just doing some 90 degree 1/8" aluminum right over top of the old drop brackets after the gussets are removed... That would get rid of 2 big ice chunks!!
7,950
6,710
I welded two 1/4" side plates to a bent 1/8" center piece that hits the two outside rivets.
If i was just using a piece of angle I think 1/4" would be required.
After the gussets are cut off the stock drop brackets and the tunnel is cut up 2" you can see just how weak the remains are.
rbanan
102
70
Sweden
Hi! Nice work! How about some riding experiences?
One other thing. Is the rear mounting hole at the same position as i were as stock?
7,950
6,710
As I said in the first post.
This is a buddies sled, i have ridden with him once and he really likes the sled.
However his last sled was a dragon and he never rode this sled with stock boards.
I haven't stopped shredding around on my axys long enough to want to ride his pro.
I'll try it out and compare to another similar pro soon.
https://vimeo.com/147052685
There it is.
We are getting a lot of snow up north so the sleds should get a workout. :)
This webcam showed 2' on the 19th. :)
rbanan
102
70
Sweden
Ok!
Nice too have that amount of snow! We havent got anything like that here in SWEDEN.
Still want to know if the skid rear mounting hole is at the same location as it were with the stock boards?
Happy sleding.
ullose272
3,372
963
boise idaho
Ok!
Happy sleding.
It is in the same spot. But the running boards are raised which make the drop down longer
Sent from my SM-G900V using Tapatalk
7,950
6,710
SMF....
Wondering if you/friend has any longer term impressions of these raised boards?
They worked just like you might think they would.
Lets you stick to a sidehill better without washing out from the running boards pushing you off the hill.
Sled blew up 2 rides later. (Like all 2011 pro’s)
I bought it later that next summer when he broke his leg and needed money.
Rebuilt it and sold it.
Someone running around alaska has it.
V
Feb 11, 2023
6
Illinois
Sheetmetalfab, can you share a drawing with dimensions of the overlays you fabbed?
