Is anyone else having problems with the exhaust valve actuator not functioning and tripping code 1407 and a couple other s?
If you just unbolt it from the cylinder and take it out without taking anything else apart it doesn't need a relearn.
But if you remove it and clean the valves its will need a relearn....Is that correct? Kind of recall something along those lines. Eric
Nope if you just unbolt the housing and remove the assembly from the cylinder you are able to clean them and reinstall them without issue. Its only when you take the assembly apart or mess with the cable that you need to do a relearn.
