M
I would be more concerned about carbon monoxide (CO) instead of carbon dioxide (CO2).
nah, he is with Al Gore...concerned about global warming!!
Will I need to get a converter to run one of these RV Furnaces? I've got a generator but those heaters run on 12v, right? So I'll either need a high priced converter or a battery?
Anyone know where I can buy vents like those? I'm also looking for a 110v plug for the outside. We used to have one on an old race trailer, you opened up the cover and it had the three male prongs in a recessed area that would perfectly fit a Woodhead electrical connector.
Any suggestions on how to insulate the floor? Have been thinking about skinning the underside of the frame for an airspace and to run the furnace ducting out of the way, but trying to not add too much weight. Otherwise I would have to add heavier axles.
Has anyone found a better deal on a new Atwood 34k than about $510 shipped? Been watching e-bay but need to get started with the project soon.
Thanks
hey I have done a few upgrades to my and other trailers. what have you done?
one inexpensive upgrade is to add cubical shelfs for storage. You know the kind that have the front door you lift and slide back across the top. bolt them on and add a plate to the top to kee stuff from falling out when you open them. they work great!
another is use tread mill belts to cover the gaps when the doors are openI hold them down with 2" aluminum strips keeps the snow out or at least its easy to remove.
here are some other upgrades, the best is the flurescent lighting (6 four foot lights) and electrical outlets. I do all the sled maintenance in the trailer. the next is the work table.
what are your upgrades?
I installed a bar and pole in mine! The nice place to hang after a ride!
I went with a "Park model" Suburban 40k btu furnace. I chose the park model so I don't have to mess with setting up a seperate 12v system inside the trailer, will just have to have the generator running when I want heat.
What kind of fitting are you guys using to get the PVC connected at the furnace?
Still on the list of things to get... Pizza cooker and stereo.
