Ok, my sled had a square ECU on it. I have located a replacement, it is a circle. I have talked to a few cat mechanics about it. I have been told, that there could be a 5% difference and I have been told it is more like 1.5% maybe a MAX of 2%. So here is how i understand it.
The ecu and the fuel injectors are matched. Square ecu = square injector . You get the idea.
So What I have been told is one is richer then square and one is leaner then square. Does anyone know?
So if I run the circle ecu with my square injectors am I leaner or richer then square?
Also, if they are just matched then why are they all different costs?
The square ecu is the most expensive from cat. and the circle is the cheapest. Same with the injectors ?????
