Dynoport Y pipe, pipe and can
The pipe is available from dynoport, I have 2 full sets on the way to my shop and I will be posting pics, and how well it runs.
Spoke with Rich from Dyno port today, because I was considering buying his set up for my Pro.. The pipe will gain your pro 4.5 hp, the y pipe 2hp, the can 0. You are looking at a 6.5hp gain, NOT 9.6hp as stated above. I already have the Slp can, so I'll probably just end up going with their pipe as well and get 7.6hp
Hope this info helps........
Dooski, is it really 18 pound savings??? Even if it didnt gain 7 h.p. loosing that much weight is noticeable.
if it knocks off 18 lbs with no hp added its worth it thats a bunch off a 435 lb sled:face-icon-small-hap
Sorry no pictures yet! I haven't figured out how to upload off phone but I will try again. No pcv or any fuel adders are being used and at 1500 elavation it seems to run better with non etanol resistor installed as the ethanol resistor runs a little rich IMO. If you give Dynoport a call (315-255-3665) it would be your best bet for info or orders.
Thanks much for the several posts on your Dyno Port Ceramic Single Pipe, Y Pipe & Can!
Our Snow has melted, most likely the end of sledding in Wis this year.
Most likely next winter I will install a Dyno Port Single Pipe & Y Pipe or a Bikman single pipe on my 800 Rush.
Use the stock muffler as there have been several trails closed, in the process of closing due to fast, loud Sleds & ATVs in Northern Wis. Plus my ears ring with the loud cans!!!
If we could use only the "SLP pipe" even if it only added 5 HP with out a PCV & SLP loud pipe I would install a SLP pipe with the stock 800 Rush muffler, but No can do per SLP???
Dyno Port Ceramic Single Pipe $499.95, Y Pipe$249.95
http://www.dynoport.wingnutwebinc.c...art&page=shop.browse&category_id=381&Itemid=1
Bikeman 800 RUSH & RMK Single pipe $449.95
http://bikemanperformance.com/snowmobile/polaris/rush-800/bmp-2011-rush-rmk-assault-single-pipe.html
The new Polaris is an impressive sled no doubt, but it could use a few more ponies from the factory. Polaris didn't deliver, but we did! Our torquey single pipe for this new sled has proven its power on the dyno, and puts a smile on faces in the field, or on the mountain! A 7hp gain with no fuel controller required, or a 10hp gain with a Power Commander Module. Not only horsepower gains, but 4 solid ft/lb's of torque were gained! Whether your climbing the steep and deep or unleashing on the trails, this pipe is one you need to have.
SLP 800 Rush & RMK Single pipe, SLP can, SLP high flow, PCV, etc, etc...... for $$$$$$$$$$
http://www.slp.cc/catalog.cfm?pageID=detail&catalogID=3&catID=19&productID=1488
How is your 800 CFI-2 Pro RMK running with the Dyno Port set up, any problems?
Thanks Much Rich!!!!!!!!!!
Well got my dynoport pipe, very nice looking, coating perfect..back to back pulls the same course...picked up 100-150 rpm adding pipe only,stock muffler,stock y pipe,no fuel box. Added 2 grams to the heel of my mtx weights,back to 8250. A very nice mod IMHO And also saved some weight. :D
On my way over to cooke for a few days, i'll try to get some pics up when I get back. Its a good looking piece. Someones posted pics in another thread if i remember
