Pulled things apart tonight.
Coils looked fine and did resistance test on primary and secondary and all tested within tolerance. Will try a different set though.
Fuel regulator. I have one of the orginal kits from mcx and things are plumbed a bit goofy. I need to move things around right now its routed.
Tank--filter---pump-----regulator---2 lines to to take fuel to rails and 1 return line to tank.
So basically the fuel system has 2 dead ends at rails. I will see if I can get a fitting put on end of rail and run a proper fuel loop. This set however has always worked but regardless I will put in a new fuel regulator and possible move some lines around.
Exhaust leak. Header and bellow look decent but my connecting pipe from turbo to muffler was hanging on by a thread. So this does not give me my current issue but something I need to fix.
Boys from sask that do mcx installs sent me a new muffler need to get in contact with them again to see if they have that connecting piece from turbo to muffler lying around. I think that was robertson yamaha??
Plan to check continuity along coil wires as well. Hopefully this shotgun approach will fix the problem. I know its nice to make 1 change at a time but its such a pain to tear everything down, things are not very accessible.
Will button this up hopefully on sunday and give it a test run.
